What do I need to power...
Drowsy
Side Effect
A set of 5in Polk db501's (45 RMS)
and
a set of Audiobahn 3.5in speakers? (60RMS)
Do I need a separate amp? A 4 channel, right? Can some explain to me why i need or if I need to do this and a 4 channel is correct, right?
Or if I get a headunit that runs 50Wx4 will that be enough?
Run them off the head unit. If you're satisfied with the sound, keep it, and you saved yourself the money and hassle of buying the amp, power+ground wires, and RCA's. If not, pick up a 4 channel amp and a Knu wiring kit. Provided you know you're not gonna upgrade, 8ga would be fine since you're only going to have a max ~50rms amp anyway.
Drowsy
Side Effect
Drowsy
Pennsylvania
budget76
