What do I need for a wiring kit?
rhuff80
21
MN
Here's my set up:
Sundown SAZ 1500
2- 12" SA Subs
Probably going to add another small amp and put in new speakers
Also need to do Big 3.
Looked at 1/0 kit from Knuconceptz
should I get the Dual kit then?
What other wires, etc would I need. Sorry for total noob questions
-1/0 front to rear
-extra battery in the trunk
-1/0 from rear battery to sub amp
-4 from rear battery to other amp
-two sets of rcas from hu to amps
-remote wire from hu to amps
-speaker wire from speakers to amps
-installation experience, which it sounds like you are lacking.
Run the 1/0 from your factory battery to a anl fuse block with a 200a fuse to a 1/0 in and 2 4g out distribution block in the back. (get a good battery if your factory battery is old) run 4 g from the distribution block to both amps. run 4g grounds, get minimum 16g remote wire to run from head unit to amp turn on. get good RCA's for signal. Run 12G from sub amp to woofers and inside boxes. and 16g from 4ch amp to doors. Done! if you need a diagram let me know.
listen to crisped, running that much power your going to need a good battery in the trunk. i suggest a deka 9a31 just because my good friend runs one and was cranking over 2k rms on it with no drops from a factory 80 amp alt. and with the batt you can skip on the distro and just run the power wires for the amps from the battery. of course fuse everything, both ends of the power wire running through the car and and the power wires to the amps,
i have the knu wire in my car and have no problems with it, super flexible and easy to run even in tight spaces.
rhuff80
rhuff80
MN
rhuff80
