what,do dots terminals on subwoofers mean?
ok dumb quetion but im rewiring my subs right now an my amp has 2pos. and 2 neg. hookups for speaker wire. it goes +-+-. if im anting to bridge it to 4 ohms does it mater which ones i put the wires in? an if so which ones to i put wire in>?
******* useless turds. And BTW my little tiburon has under 200BHP with a 6 speed manual and would still smoke your old heavy ****** truck.
Yes it does matter what terminals you plug it into...bridging it would be hooking positive from sub to the first positive and the negative from the sub to the last negative.
Ricer alert!
you aint a badass unless you have kickers!
This is why this forum will never be a good resource besides the occasional good deal on a driver. Idiots like you. What the **** does it matter what my driver of choice five years ago was. Sorry I can't afford to pour thousands of dollars into a system. If you have that big of problem with it you can mail me your subs and I'll trade you.
//content.invisioncic.com/y282845/emoticons/rage.gif.0ad8a6e5565b5fddce406566fdd05149.gif
You will want to bridge your amp. Check the manual to be sure that you use the correct terminals. One channel's (+) and the other channels (-)... oh and btw (.)(.)
I'd like to see that, my friend has the same car.
this stuff only happens when some new guy comes in here trying to act like he owns the place and pushed one of the big boys...
if you read back through your own posts, you can see where you screwed up and started this. and yes, CA is a bit like the wild west of forums, not nearly as much as it was but im betting you spend time on caco or smd dont you...
hondaracer48
hondaracer48
texas
Why So Cereal?
