What did I do wrong? Nothing plays when faded to front
ncsportic
I installed an amp in my '99 Taurus to power my speakers (no subs). All the speakers produce sound, but nothing comes out of the front door speakers when I manually fade the settings to the front via my cd player (worked prior to amp installation). I played with all settings on both the cd player & amp. I know I should just be happy that it's working, but that's not good enough for me. I'm afraid that all 4 speakers are acting as if they were all to be producing from the rear channel. Meaning, I may be missing sounds that are supposed to be coming from the front channel. Is the fade feature even supposed to cooperate with an amp? Please help me out.
Specs:
Older Kenwood deck (45wX4, 1 Set of RCA Output, will be upgrading in a few weeks!)
Infinity Reference Series 7541A 4-Channel Amp (140wX4)
(2) Pioneer 6 1/2" (220w max, located in front door)
(2) Kenwood KFC-6982ie, 6X9 (500 watt max, rear deck)
4ga. Monster Power Cable, 80A fuse
16ga. Speaker Wire
To the speakers (spliced into factory speaker wiring already located in trunk. triple-checked that splicings were performed on correct colored wire.):
Connection Side (left front, right front, left rear, right rear speaker wire all correctly spliced to factory speaker wiring. again, not the issue):
RCA(s) (Do I need the Y-Splitters? I've tried every possible combination, no luck. which is the correct way?):
its not gonna fade because you have your y splitters set to 1 set of RCA cables which is controlling the signals for both your front and rear..
but then again i only looked at the last pic so i may have missed alot.. kidna gone right now tbh lol
Btw i like your 16 gauge ground wire.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
Thanks guys. Yeah, about that ground... ha. It's the only thing I had at the time. Replaced it today with 4ga. I was told I would be fine with that ground wire, take it it's a big no-no?
ncsportic
ncsportic
Green Bay, WI
ncsportic
michigan born
    May 14, 2026
michigan born
    May 14, 2026
