What could be the problem?
  • 2
HawaiianHaole
Delaware
I am having some difficulty determining the origin of a problem I am having. All of a sudden, each morning my driver door speaker is out. To get it back on, I adjust the balance and fade directly to this speaker. Give it a little volume and it kicks back in. Then I adjust the balance and fade back to normal settings and I am good to go.
I tried swapping the RCAs on the amp. I figured if there was a problem with the amp or the headunit, then the problem speaker would then be the passenger door, but it stayed at the driver door.
I assume all that's left is that the speaker is shot, there is a bad connection, or an off chance that there is something wrong with the speaker wire.
What would you do next? I figure the first thing to do is rerun some wire from the amp. Does it sound like the speaker has gone bad? It doesn't sound like its crackling, like its been blown. When it eventually comes on, it actually sounds fine.
Thank you for any insight you might have...
The starting ask on diyca.com is $2,500, so no telling what they want in the end, maybe $500k lol. Funny that caraudio.com is no longer valid for...
19
76
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
771
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
961
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
620
HawaiianHaole
HawaiianHaole
Delaware
helotaxi
    May 12, 2024
Brendon Jenness
    May 11, 2024
