What class would I run in?
ace_800
Ok seeing as this will be my first actual comp, others were local one. I have no idea what class I am. I'm running an inline 250amp fuse atm but switching it out to a 100 or 150amp. Its near the stock battery that runs to the kinetik in the back then to the amps, both the eclipse and exile listed in sig.
I don't have any mods or anything cut. sub is below the window line. Anyone help?
Yeah, doubt I can run lower than 150amps seeing as I'm pulling ~1600 from the exile and 500 from the eclipse. I called exile today and was told it actually does 2000@2 and 2400@1, not stable at 4.
you can //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i ran my 500.1 at .5 on 2 80s in s3 and now i run 2 o2 audio 2500s at 1 ohm strapped on a pair of 80s
Ok. If you are not a member and are not trying to earn points, they will go by your amp rating since you actually do not have proper fusing. So you will be put in either as 2 or street 2 unless your box is over your back seats or you have the amp or batteries outside the cargo area. If you want to put a fuse on your system to count, it'll have to be between the back battery and your sub amp. Other amps do not matter. And I have ran an 80 amp fuse on a aq 2200 at 1 ohm for even daily, did not blow it so you'll be fine. Good luck
ace_800
ace_800
Okinawa, Japan
Davecubs14
ThxOne
    May 13, 2026
