skmfkr
and how do i fix it? also damaged the ground wire, seems this is def why my amp is going into protection, the power and protect lights both light up
To the amp terminal. You need to use clean contact points all around...it was 4awg wire, i took a pic of it but the cam didnt save it. bad connection where to the amp or ground point? or should i have strip the wire more? cuz it was too long and was liek balled up on the end so i cut some off
Can you scrape any of that shit off of the termainal or did it melt?looks like crazy oxidation to me.
I've never seen a pair big enough to strip wire that big. I just use a standard box cutter with the blade in the first locked position. It sticks out about a 1/4 inch.well i restrip the wire and it works fine now....but i still need to restrip it cuz i was using the biggest stripper i have which is 10awg so i cut some wires, my razor woudnt cut thru the coating for shit. but yeah thats melted plastic around the terminal i can provly use sand paper to clean the inside out, i emailed kb audio with a pic. im waiting to see what they say about it. i might also need to email RE to get new terminals and just replace them
where can i find some real wire strippers and crimpers for 1/0-4awg wire?
I just use a vice and a hack saw. Its not too bad if you cut it as close as possible to the vice.yeah i cut it off, i got i to go thru just took some time, im gonna order some cable cutters to cut the wire and hopefully tomorrow i can find a wire brush at lowes that will get into the terminal to clean it out
is this the 35.1 you were tryin to sell me yesterday?shit man that's one unhappy 35.1D mine even looks better and it had 9 output transistors blown (i did buy it as broken though) //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif board was burned lol
And I thought you said it was working now...yeah i got a drill i can use, and about the voltage drop i had a DMM on it when i first noticed the protect light but and even now when it cuts off the voltage doesnt drop. im looking on the site right now for it. whats the name of it? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
i found a brass brush
