What capacitor do I need?
What's your battery's voltage when everything is on? I would suggest a newer/bigger battery before I looked into a cap.
I'm having some trouble trying to get a number off the battery. With the car off, I got 12.6 VDC and then I tried to get it again and I keep getting 0. Am I doing something wrong cause I can't seem to get a reading again..
Your meter should have symbols similar to this
Make sure you have the meter set to Volts DC because your battery is DC. Also make sure you have one lead of the meter on the positive terminal of the battery and one lead on the negative terminal. Make sure the terminals arnt corroded and are free of dirt grease ect for an accurate reading.
Turn your stereo up the loudest you ever listen to it at. Turn all the bass boost, gain, everything to 0. Slowly turn the gain up until it sounds like the sub is not sounding right, and turn it back a little. That is the best you can do.
Do you have a digital Multimeter? If not you could get one at Sears or something. It would make doing that a lot easier. They make this little pocket one that's like 22 bucks. Some are cheaper, some more expensive. Everyone has their favorite DMM, but get one if you don't have one.
turn all of your stuff on with the car running. what does your dmm say on the battery?
i got 12.2 vdc with everything on except the music. i know that when I turn the music on, the voltage is going to drop. I get 14.5 when my engine is running with all the accessories such as high beams, heater, etc. off.
Yeah, your alternator just isn't very strong. If your alternator can barely handle its own accessories, then your audio system isn't helping much. You are probably low voltaging your amp and sending it into protection.
If your voltage is sagging with the music off, you for sure have either a dead alt or battery. Chances are it is the alt, but a dead battery will draw a lot of current as well, which will appear to be a bad alt.
How many cranking and cold cranking amps does my battery need to supply enough power to my car and my amp. My amp is 750 rms watts but it's underrated.
Jer510
Slap Addict
Jer510
Oakland, CA
zack1442
ThxOne
    May 13, 2026
