What capacitor do I need?
Jer510
Slap Addict
I have a Kicker ZX750.1 and 2 Kicker CVR 12s. I had this problem, my subs cut out and then came back on repeatedly when I used my car's high beams or used my car's phone charger. I drive a 96 Camry. Will a capacitor solve this problem and what farad capacitor do I need? Also, does the brand name of the capacitor make a difference in sound?
You need to upgrade your batteries. Your alternator is struggling to keep up with the current draw, and a little more battery reserve should help it out.
what kind of battery should I replace my old battery with?
If your running your current system in your sig (750 rms), I think a optima redtop or yellowtop up front should solce your problem. Also do the big 3. (check the wiring/ electrical forum there is a sticky there for it)
would a battery solve the sub cutting out when I use my high beams or car phone charger?
Have you checked your voltage drops? I'm guessing that you're pulling more current than the alternator wants to produce and your voltage is dropping to a level low enough to kick your amp into protect. You need to check your voltage drop and also check if the amp is going into protect.
when I check for voltage drop, I check the battery in the morning before i start the car and after its been running for a while right? And do I use AC volts with a dmm and connect the positive to the positive terminal on the battery? And how many minutes should I wait to check if the amp protection light comes on?
A cap will fix your dimming problems. You dont need to get a new alt and all that bull. A 2 fard would go well.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused:
//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif//content.invisioncic.com/y282845/emoticons/thumbsdown.gif.d22f25895e9b40f2300c953691dacfa2.gif
+1
a cap would "bandaid" the problem like someone posted earlier....it wouldnt fix anything really.
Jer510
Slap Addict
Jer510
Oakland, CA
zack1442
