What are the things that can cause a amplifier to blow
Crappy design can also cause an amp to go poof. I remember a local shop telling me that 25% of their Soundstream Reference S series blew caps upon first power up! That is what gave them the nickname of Smokestream back in the day.
Also, the Orion HCCA G5 series had an approximate 50% failure rate and was notorious for catching on fire when it did go poof.
I just wanted to throw that out there because not all amplifiers blowing is a result of improper installation.
A friend of mine had a hcca g5 that caught fire lol.
People trying to do things on an amplifier that it isn't designed or built to do. Low impedance, low voltage, bad vibration. Everything else that is listed above. Then the company gets blamed for it.
I agree with you, i've had my amps a long time without any problems, on this forum , I see people blowing amps left-and-right, (i remember my young days,when i was blowing amps.) I learned quick that if you stick to manufactures specs, u won't have a problem.
p.s I just told my brother the real reason, 20 yrs ago why our first amp we bought never worked, it was a coustic 190 I blew it up when he was in the house, tring to hurry and hook it up, not knowing anything about ohm loads, power requirements or anything. but i've learned , and so will others
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
carter1010
carter1010
Charlotte NC
corrie32
