What are some Good Amps that Do 300-400 wrms x 2?
if 180x2 is not loud enough man, then eaither;
A. your hearing is is seriously damaged, and it will only get worse
B. your shit is installed wrong.
180x2 is a fu*king SHITLOAD of power for components. 100x2 is enough to make you go deaf, eaisly.
ha! my hearing is not damaged at all....I could hear a cat fart....I just have a high threshold for loud s***....Theres a couple people here that have Components with 300-400 watts goin to'm.....I just want to be another one of those guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you measure the voltage at the speaker terminals you will find that their components are not getting nearly the power you think they are.
Just because the amp is capable of 200 or 300watts x2 does not mean that it is actually putting out that much power, once you set you're gain and turn on a high pass filter voltage output decreases significantly.
also you gotta look at the THD or watever. cuz you can run an amp much higher than the actual rating, but the distortion will be much higher.
once the amp is driven past its rms power it will begin to distort and it all depends on the amp and how its made and with what was made, while driving a usamps into WAY more power that its rated it will likely go over the 1% THD level that the brutus is already rated at for its rms that doesnt even do.
Starky
Starky
michigan
chinny
