What are good ring terminals
I have the knukoncept's ring terminals under my hood and they haven't let me down since. I also have the Tsunami ones from CC that work fine, but at $7 they are expensive.
Doing grounds - I would not use set screw terminals, they can not be bent to fit the application. Also see what kind of room you have at the ALT - the bolt on the back may not be long enough to fit the set screw type there either depending on application.
Dj-torn
Still learning...
Dj-torn
Fairchild, WA
knukonceptz
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
