What AMPLIFIER do I need! HELP!
LHSroller
I recently bought a Visonik Triple 10" Bandpass box (VB3P10) and I need an amp to power them (no $hit huh?) what should I get? the box is 800RMS 1600 peak! The cheaper the better, although it doesnt matter, not over 1000 please!
Look into Earthquakes PHD its about 1000 watts but shouldnt be a problem because each sub is only about 65 watts over rated power for each sub. I am drawing a blank for everything else at the moment.
Mike
the crossfire bmf 1000d is one of the best amps on the market each one usually pushes 1600 watts and I have seen one rated at 1900 watts the BMF is True(Bad Mutha F*cker) and used with two BMF 12" subs in a 2 cubic FT box or larger and you'll think you had 4 12's
Are they any good? The 1400 watt one is 700 RMS and should work...right? And, that way it would look good! And if anyone uses one, does it come with a built in crossover or do I have to purchase one?
stop playing get the 1100d its 1ohm stable it should hammer those woffers if thats the correct box for them. EarthQuake amp fry to fast they cant take punishment for to long . Crossfire anps don't sound all that.
Tino :from Aztech Car Audio
Originally posted by Unregistered the crossfire bmf 1000d is one of the best amps on the market each one usually pushes 1600 watts and I have seen one rated at 1900 watts the BMF is True(Bad Mutha F*cker) and used with two BMF 12" subs in a 2 cubic FT box or larger and you'll think you had 4 12's
LHSroller
LHSroller
Welch
audiolife
RobGMN
    Jun 8, 2026
DEH-P7700MP.mp4
lbn.wrks
    Jun 8, 2026
