what amp for vanadium 12 ?
HiFonics BRZ1200.1D should suit you well. It's actually quite a bit more powerful than your sub is rated to take, so be careful with it.
Really, practically anthing that supports 1 ohm (you'll be running 1.5 ohms) will be fine, since that sub doesn't take much power.
thanks,
so this amp is bit too powerfull ? are there any other amps that are at a lower price ? i had a hifonics hercules viii at 2ohm but its not working anymore. What do i need now ? 1 ohm with about 500-600 W ?
I'd say look for a 1-ohm rating of 600WRMS or more. You will be at 1.5 so you will get about 2/3 of the power of the 1-ohm rating. You can use an amp with 200000000WRMS if you want - it would just be very easy to blow your sub with it if you didn't set the level correctly.
Onkel
Onkel
Germany
dragonrage
