What Amp For 2 Pioneer Premier's 3004 ?
  • 4
Great subs...... I used a 750.1 Autotek Supersport for a few weeks when I had 1, then put a Autotek SS1900.1D on them. I'm sure they can take more, but I had to get what I could afford.
I had a hifonic bxi 1606 on them slot ported box @ 1ohm tuned to 30hz and they pounded big time. Now just bought a hifonics 2608 (2600w rms) as I felt they needed much more to drive them
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
peanut123
Buttcheeks
peanut123
Los Angeles
riddla
    May 12, 2024
Brendon Jenness
    May 11, 2024
