What amp for 12 L7's
four_low
I have 2 2ohm 12 inch solobarics for my new setup but cant decide on an amp
Im either going to get a kicker kx1200.1 Or an audiobahn flame amp
I preffer an audiobahn for the setup im putting i my 2000 chevy silverado
the Audiobahn A2150HCT says it runs 1 x 600W RMS @ 2Ω @ 12.5 VDC
Would this work or what would be a better model ?
The audiobahns directly fit into my show setup thats why i need that style.
Any feedback will be appreciated. //content.invisioncic.com/y282845/emoticons/bowdown.gif.b85b23b82970bd22fb6b549c3392f016.gif
if your running 600 watts rms to 2 subs are you sending 600 rms to both subs or by sending to 2 is there a power cut?
Sorry for some dumb questions, im just getting into the technical aspect of it
Audiobahn A1500HCT 2000W RMS High Current Series Mono Amp
State of the Art High Current Amplifier Circuitry
Regulated PWM MOSFET Power Supply for Stable & Reliable Power
Double Sided Printed Glass Expoxy Circuit Board
Signal to Noise Ratio: > 100 dB (+/- 1 dB)
10 - 20 KHz Frequency Response
Bass Knob Control with Blue Backlight Knobs (0 - 18 dB)
24dB High-pass Crossover: 50Hz - 750Hz (Variable Type)
24dB High-pass Crossover: 30Hz - 120Hz (Variable Type)
20Hz - 45Hz Variable Subsonic Filter
Bass Boss Frequency from 40 Hz - 100 Hz
RCA Throughput Connection for Easy Expansion of Amplifier
4 Way Protection Circuit. Thermal, Short, Overload, DC Offset
Dual Cooling Fans with VU Metering Response Output
Cobalt Blue Illumination and High Gloss Chrome Finish
Dimensions: 3-11/16"H x 12"W x 18-1/2"D
2000 Watts RMS x 1 @ 1 Ohms
1000 Watts RMS x 1 @ 2 Ohms
500 Watts RMS x 1 @ 4 Ohms
What about this one?
Someone told me mono amps arnt good for DVC is that right ?
That person doesn't know what the hell he's talking about.
There's 2 good ways to wire up (2) 2 ohm DVC subs:
So you're gonna need an amp that puts out roughly 1000-1200w @ either 0.5 or 2 ohms, so each sub will get 500-600w. The KX1200.1 only puts out about 600-700w @ 2 ohms.
The Hifonics BX1800D (900w @ 2 ohms) or BX2200D (1100w @ 2 ohms) would be good amps. Or the above mentioned Audiobahn A1500HCT would also be good.
four_low
four_low
louisville
denim
