What amp do you guys suggest?
BloodyDischarge
WV
I'm lookin at 2 Alpine Type-X subs. I don't know too much so I would appreciate your opinions. Here are the speaker stats:
12" subwoofer with dual 4-ohm voice coils
carbon fiber/aluminum honeycomb cone with high-roll Santoprene rubber surround
cast aluminum frame
frequency response: 23-200 Hz
power range: 500-1,000 watts RMS (500 watts per coil)
peak power handling: 3,000 watts
sensitivity: 83 dB
Now I know nothing about amps (meaing channels, ohms. and such). I'm currently looking at the MA Audio HK4000D but don't know if this will be a mistake or not. I wan't to be able to power these subs fully. Here are the stats for that amp:
4000W Digital Class X Competition mono block amplifier
1800W x 1 at 4 ohm (14.4V)
3600W x 1 at 2 ohm (14.4V)
2000W x 1 at 4 ohm (17V)
4000W x 1 at 2 ohm (17V)
Temperature, voltage, output level LCD display
Thermal/short/overload protection circuitry
Platinum-plated screw type RCA jacks
Double-sided black epoxy PCB board
Platinum-plated block terminals
Fully unregulated power supply
Stainless steel finish heat sink
Quiet fan cooling system
Remote gain control
Full MOSFET circuitry
10-350Hz frequency response
Variable 0-18dB bass boost control at 45Hz
Amp preamp outputs
Built-in crossover
Thank you for reading
Im gonna guess you will run this at 4ohms? Cuz 2 would be overkill unless you have 3 or more subs..//content.invisioncic.com/y282845/emoticons/imo.gif.3a57bcc70a4835dc53e86ffae1a0b041.gif(u might get a 3rd or 4th sub later if what im saying)
Patrick - I got a 2005 chevy colorado ext cab... just barely enough room for 2 twelves...but they do fit. No room for a 3rd though.
Bri - Pretty much limitless.
c2k 9.0>arc 2500. zapco>arc anything
Robert Zeff>Robert Zeff>Robert Zeff> //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
he aint with either one anymore.
BloodyDischarge
BloodyDischarge
WV
blue
