Addvreviations?
solomon
I was jes hoping one of you guys could give me sort of a rundown on what these abbreviations mean and what they mean pertaining to the sub.
Qts:
Qes:
Qms:
Fs:
Re:
Ls:
Lp:
Rp:
Dia:
(% shift)
16.3 %
Vas:
Mms:
Cms:
Bl:
n0:
SPL:
Sd:
Xmax:
Qts: Ich be ein littre volumen
Qes: Frouline Thielle masse dans unkt
Qms: Das smalle tussen volumen
Fs: sucht vein resonat
Re:
Ls:
Lp:
Rp:
Dia: eist measured ein metres
(% shift)
16.3 %
Vas: volumen ein littrehosen
Mms:
Cms: dust ein commas
Bl:
n0:
SPL: vor notra cors bas
Sd:
Xmax: est ein schiznit
That's what I know... I'm sure the others can fill in the rest.
Fs is the free air resonant frequency ...... the freq. that it vibrates the most in free air
re is the actual impedance (ohms)
qms is mechanical q.......spider surround cone weight
qes is electrical q.......magnet strength VC
qts is total q
q is the subs tendancy to resonante at fs
sd is cone area
Vas is the volume of air that has the same complience as the subs suspension......... basically tells you the looseness of the suspension (bigger vas=looser sus)
xmax is how much it moves one way, u can go beyond xmax on some subs (not much on the xxx) but anything over xmax is non-linear (shitty sounding)
bl is the strenth of the motor
spl is how loud it is from one meter away wih one watt
rms is the continuous power it can take
max is usually the peak power it can take for a split second
Fs is the free air resonant frequency ...... the freq. that it vibrates the most in free airre is the actual impedance (ohms)
qts is total q
sd is cone area
thanks for that...
thanks for that...
careful...most of it was wrong //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
For example:
No, Re is the DC resistence. "Actual" impedance will vary by frequency, etc etc.
Nominal impedance (what the speaker is "rated" impedance wise) is Znom.
No, the weight of the soft/moving parts is Mms (moving mass).
No, motor strength is Bl
Great link explaining T/S params: http://editweb.iglou.com/eminence/eminence/pages/params02/params.htm#Q
solomon
solomon
canutillo
squeak9798
