Umbra
Hobbyist & CA Tenderfoot
A short anecdote/rant good for little more than a laugh.
I've got these pair of RFP He2s. One's fine - It's a ******* champ. The other is.... problematic. When I bought them used the one had a failed connection between the leads of one coil. I cut the dustcap off it and saw the connection from the tinsel to the coil had severed, so I tried soldering it with the little bits that I could access, put some hot glue over it, stuck the cap back on and reinstalled it. It worked, for a couple months, then the problem came back. Cut the thing open again and to my surprise the problem is with the other coil. Did the same fix with a slightly modified technique (twisted the bits upwards in parallel, rather than perpendicular to one another and added heat shrink tubing). Rather then stick the cap back on with CA glue I used Gorilla glue. I had a bit of excess seep out, but I cut it off. I reinstall it, it works for a couple months, bam! Problem comes back a third time. I hastily cut the dustcap off for a third time, but the puffed up Gorilla glue threw me off. I'm cutting and all of a sudden I'm seeing spider. I ended up cutting through the entire circumference of the cone! The ******* dustcap didn't even come off (it did with a slight pull though). Turns out one side of the tinsel-coil connection came undone from the first fix. I'll see if I can patch it up once more and maybe fortify the other one while I'm in there.
I reattached the two pieces of the cone with Amazing Goop. I'm going to let it sit a couple days to reach full strength. I'll address those connection issues while I wait on that. It's a relatively nice sub. Looks sharp, built nice, sounds nice. It's nice to me, but I know a lot of you would laugh at 400W RMS). If I can fix it, fantastic - I can keep the pair, but I don't think it's worth sending off to be professionally reconed and the connection issues fixed. In a couple months time I'd like to replace them with something like an AB XFL 12 anyway.
I might try crimping the connections this time around. Can anyone link me to such an object? Do you think a good Amazing Goop connection would hold up on 400W RMS? Is there anything I can do to strengthen that bond, like gluing a patch down?
