ThomasG
If you have any knowledge about welding and can answer any of the following questions that would be great
What are the two purposes of the regulator on an oxy/cetelyne rig?
What are five potential hazards of arc welding?
Explan the difference between AC,DC straigh, and DC reverse polarity
What are five types of materials used to make welding rods?
What are the two gauges on the regulator used for?
Name 3 purposes of flux on an electrode.
What do the numbers on the electrode mean?
Why shouldnt you weld with wet gloves?
What shade of lens should be worn when arc welding?
List two reasons why you shouldnt arc weld without proper coveralls?
What shade of lense should be worn when welding with acetylene?
Why should you warn people around you before you strike an arc?
At what length should you properly discard used welding rods? why?
Why is it important to stand at the back side of the valve when opening gas cylinders?
Why shouldnt you arc weld on a wet floor?
When using a drill press or hand drill should you hold the work by hand or secure it with a clamp of vise?
How far should the oxygen cylinde valve be opened?
At what psi does acetlyne become unstable and haardous?
What equipment should be worn in the shop at all time?
how far should you open the acetylene cylinder valve?
in the shop, your acetylene pressure should never be set higher than__ to __psi
The oxygen hose is colored_____and has____handed threads.
What are 3 charcteristics of oxygen?
What substance is used to control the unstable properties of acetylene?
How can you keep power tool cords from cracking?
What are four characteristics of acetylene?
Why shouldnt you cut or weld near concrete?
How do you properly clean a torch tip?
If a flashback occurs, what should you do?
What are two simple rules to keep plugs and outlets from breaking and prevent arcing inside of power tools and machines?
What is the proper way to move a cylinder?
What should you inspect carefully before using grinders of the chop saw?
Why shouldnt you adjust the amperage while someone is welding?
If a ham sandwish costs 15 cents, how much does a pound of bacon weigh?
