I'm not, I picked up a Kenwood M1-D to do the job. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifi would be worried about you being able to run all that from your 5.1 receiver...i have a pair of older klh floor-standing speakers (similar to the 9250b's, but with 15's) , they were weak off a High Current Cambridge audio azur(150w at 4ohm) and it looks like you should be demanding more power than that!?
ah...niceI'm not, I picked up a Kenwood M1-D to do the job. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well, the tweeter is sealed back do I wouldn't have to chamfer anything to help it fit, but it'd be a tight squeeze to get the tweeter and the wiring through a hole that small that would also allow me to flush mount it. In short, the panels would have to be next to identical, and I'm not sure my woodworking abilities are that good for something with such a low tolerance for error as a flush-mounted tweeter. With a single baffle, it's fine. but to get the holes to line up exactly will be kinda trying for me. Any suggestions on how to do it easiest?re: tweeter , don't worry about it right now.
re: double baffle design, why not double baffle from bottom to top, instead is stops
at the woofers? The seamless design would be easier on the eyes.
For a double baffle? Glue the two layers together first, then cut the holes. Treat it like a single piece of 1.5" MDF.Well, the tweeter is sealed back do I wouldn't have to chamfer anything to help it fit, but it'd be a tight squeeze to get the tweeter and the wiring through a hole that small that would also allow me to flush mount it. In short, the panels would have to be next to identical, and I'm not sure my woodworking abilities are that good for something with such a low tolerance for error as a flush-mounted tweeter. With a single baffle, it's fine. but to get the holes to line up exactly will be kinda trying for me. Any suggestions on how to do it easiest?
Or one big port on the front... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifJust a note on the tweet "overall looks like a stellar budget DIY project"
Quoted from Zaphs site...
Hi-Vi SD1.1 ($13) - "A" version tested. Nice performance for a tweeter of this price, and probably worth the few bucks more than the K1, but there are some consistency issues. Twin impedance peaks cause a slightly bumpy low end that smoothes out in box with typical baffle diffraction peaking. Slight rise in the top octave goes to flat a few degrees off axis. Make sure you have the shiny dome shown on the right. The dull one on the left measures horribly.
Also port that biatch to the rear, twin front ports make it look like a $20 swap meet wannabe prosound cab found in the dorm room of the local campus drunk.
Yeah, but you have to take everything Zaph says with a grain of salt. He may not like it, but the people buying it have all given it a perfect 5/5 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifJust a note on the tweet "overall looks like a stellar budget DIY project"
People give total crap a 5/5 a lot of times haha. Also I just pointed it out so you can watch out for the different dome types. He has tested both and the one version SUCKS.Yeah, but you have to take everything Zaph says with a grain of salt. He may not like it, but the people buying it have all given it a perfect 5/5 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifhttp://www.partsexpress.com/pe/showdetl.cfm?Partnumber=297-416&vReviewShow=1&vReviewRand=3432827#reviews
And I'll look and see how it looks ported to the rear w/ complete double baffle; it looks good to me aesthetically as it is. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
