4runnercrazy
Mattchu
the amt of copper is too small, how bad of a idea would it but the run 2 wires for each of the + and -
yea, more like would it be a good idea or notFrom what I read it doesn't matter in this case. He was simply asking if he could do two runs of speaker wire per terminal.
"12 AWG" speaker"4 AWG" power and ground
around 350 RMS
okay im not that stupid //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifYes, you can do that. It will double the amount of copper. Just make tripple sure you don't switch the +/- on one of the lines or you could smoke one of your amps.
but the speaker wire has very little copper in itYou don't need to double it. That's plenty of copper for that. Also it's okay for speaker wire, but I would not reccommend this trick for power wire. Each power wire would have to be fused seperatly.
You said it's 12 gauge speaker wire. What else is in it other than copper? If it's 12 gauge speaker wire, then it's fine. If your having problems, it's not the wire.but the speaker wire has very little copper in it
the reason why im asking is that its not as lo9ud as i know it can be, its being bridged at 4 ohms for about 400 RMS on a hifonics (so more like 300-350) and it just isnt hitting
anything else i can check?
What you are missing is, the current flow through the wire causes resistance. It wont all flow through one or the other wire, it will flow through both.Electricity will take the least resistant path so doubling up wouldn't help. The wiring you described seems adequate but if you still want to upgrade, go with bigger wire, not a double run of the same size.
