Weird computer prob
Of course it will change the resolution, when using two displays you can det up dual view which changes assigns resolutions for each display respectivly, however when you are using a full screen setting like for games it will try to force the resolution set in the game on both displays regardless if it can display it or not. This doesnt mean the game has settings higher that your tv can display, they may just be 16:9 settings that your tv cant reproduce, so dont think you tv doesnt work as advertised or anything //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. Hook up both monitors at once and adjust the game settings until you find a resolution you can work with on both. IE my tv will handle 1024x768 (and around that in widescreen) but if i run a game at 1600x1200 i can only view it on my monitor because my tv wont support a setting that high.
I set it so it uses the lcd tv as the only monitor. I can never get that dualview thing to look right at all. Thats what I can't understand why it wont work. I make sure I set it to use only one monitor, and change it to the TV.
btnhfan
Hail to the King Baby!!!!
btnhfan
CT/ GA Tech, Atlanta
faulkton
