wedge enclosure port
dannyz122001
looking to do an enclosure that can be broken down into a wedge and a rectangle. however, the port will have to be on the slanted face of the wedge. I was wondering how I should run the port.
the sub is a solox and the port opening is shown above it. i drew the port the way i thought it could go but im not sure.
http://i274.photobucket.com/albums/jj259/dannyz122001/aa.jpg
any help would be great. thanks
i thought about doing that, but if i do, i wont have a large enough angle to have room for the sub. meaning if the top is wider, the angled piece will be almost straight up and down, and it will not be long enough to fit the sub
No you don't need to slant the end. Just make sure both ports are the same length and measure down through the center of the port like this:
The red line is how you should measre the port.
How are those ends on the top port not slanted //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif That's what I was talking about^^^
well its actually not that simple. i have a f-150 supercrew and i am removing the back bench and replacing it will 2 captains chairs. the enclosure will run between the rear captains chairs, from the center console to the back of the cab. the front of the box (the smaller side) will butt the center console and the larger side will be against the rear of the cab.
dannyz122001
dannyz122001
Baton Rouge,LA
groundpound4200
