Watt checker correct ? ( HK-4000D)
supa_c
Abministrator
Well, i just got a free DMM in the mail from a local ca.com member
( thanks joseMceee)
So !
i thought, why not see what the good old MA Audio HK-4000D pumps out.
Well, i got 135.8Vac maximim from my "testing".
According to this wattage calculator:
http://www.conceptconcept.com/download/measurwatts.pdf
at 14.4Vdc the amp is supplying 6K RMS of power.
Now, is this correct ?
Im in shock and awe...but id rather know if that is for real.
maybe ur car just cant supply the amperage the amp needs to put out that amount of power, when you think about it, for 6kw at 14.4V you would need like 400+ amps. Right?
it's a number, that's about it.
#1, it's peak, which really has no meaning as far as how amp power is rated.
#2, it doesn't allow for impedance change of the load as the frequency changes (which is WHY dummy loads are used for power tests).
Pyramid would be proud of you though.
actually, i did the RMS power.
the " peak" was 9K something.
I know " its not a real test", just having fun with my new DMM.
give me $20 and ill get it benched
Sure he does - 800cca is quite a bit of current in my book.
Ever seen the current this amp draws?
It has no problems pulling 400a...can pull even more when you clip it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You're gonna want to end up at around ~200aH worth of batt's to get this amp goin...
Snova- 480A at 12V.( Benched)
Can we say " battery killer" ?
Jose, sounds correct.....freakin concept //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
supa_c
Abministrator
supa_c
In a chair
pro-rabbit
