regal8r
I <3 my CRX
hey, i was wondering if someone on here, like squeak, could teach me about crossovers...like the differences between active and passive, etc...thx.
another important crossover fact: whether it is active or passive depends on exactly where in the entire system you crossover the signal....if you have the crossovers installed in the speaker wire right before the speaker, it is a passive setup, but if you have a crossover used on the signal wire coming out of your source (that is, BEFORE the signal gets to the amplifier) then it is called active crossover:
CD player line out --> amplifier --> crossover --> speakers (this is PASSIVE)
CD player line out --> crossover -->amplifier --> speakers (this is ACTIVE)
But I guess if we really wanted to be fickle about it, we could use Fmods as an example of a "passive" xover that comes prior to amplification //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifgood point squeak...i didnt disagree with alphakenny because in most typical situations, his explanation can be correct...i dont find adjustable passive crossovers to be as common as fixed ones, and i also dont find fixed active crossovers to be as common as adjustable
HOWEVER you are indeed correct
*applause*An active crossover is a crossover that needs a power input. A passive xover is an xover that operates without a power input. Active xovers are typically located in the signal path prior to amplification (in the HU, between the HU and amp, in the amp), while passive xovers are typically located after amplification between the amplifier and the speaker. Active xovers are typically much more flexible by offering adjustable xover frequencies and possibly xover slopes, while passive xovers typically offer only fixed frequencies and slopes.
