Wanted: 1 good sub to replace 2 bad subs
I made the mistake of going into a car audio store and listening to some quality subs in a sealed enclosure, oops. All of the sudden my MTX Terminator sounds like s***, I'm optimistic and want to think that there is one good subwoofer that will be louder two bad subs but here's the catch, i want to do it with -150 watts less power. Currently wired in 2 ohm and pushing 500w to a pair of 400w (200 x 2) subs, my goal is to run channel 5 in 4 ohm at 350 watts x 1 and drive a single 4 ohm 350 watt subwoofer, preferably in the sealed enclosure but may switch to ported. The reason for reducing power to the subs is simple, less strain on my electrical and charging system, i want more bang for the alternators buck..
ill make you a deal on a 500w rms eclipse that likes sealed boxes and is in mint shape. 150shipped which is rediculously low but im in a bind and it fills your criteria look it up
eclipse 8122dvc
but its dual 4 so you would need to wire to 2ohm and lower the gain but that would equate to the same thing as running 4ohm as efficiency isnt much different running lower power percentage at 2ohm in comparison to full throttle 4ohm actually running 4ohm might be worst depending on how hard you puch the amp
gstokes
FÜKENGRUVEN
gstokes
Beaverton, Oregon
winkychevelle
