//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif would be a sick set up!You aint getting an 18 cubic feet box in a trunk.
If I had 18 cubes I'd do four 18" Nightshades
Well damn I was hoping he meant 3-4k for each sub, lol. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif would be a sick set up!
sadly, OP says he only has 3-4k to work with.
**** that trunk really is big, I think his budget for subs was like $1k.....Ive done builds in these cars. If I owned one, I would go for 6 15s sealed firing up. Or 12 12s sealed.
The trunk is actually 22.3 cubic feet total. 2 cubes are for the ledge that splits the cabin and the trunk (batts can go there). You can fit a legit 18 cube box in that trunk WITHOUT building it inside the trunk. The trunk is ****ing massive.
Why can you only fit one alt? Fairly common to see Lincoln Limos with dual alts. Try "google" you will be amazed at info on this new thing called the internet.I'm not doing an SPL comp build believe it or not. I'm going for a 150+ DAILY in a trunk. I'm looking to tune no higher then 35hz. I can only fit ONE 250 amp alternator so I don't see myself doing anything more then 5k RMS. I'm going to mount my amps on the box and the batteries will most likely be mounted in random areas where possible.
http://carphotos.cardomain.com/ride_images/3/2707/1921/31765960040_large.jpg
Show me where another alternator can fit.
Sucks that I'm not driving a Limo //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifWhy can you only fit one alt? Fairly common to see Lincoln Limos with dual alts. Try "google" you will be amazed at info on this new thing called the internet.
