Want to put 20's on
you could probably do it, but it would ride very rough cause you woud have to have very low pro tires. I think 20s are too big go for like 18s. and you spelt Chrysler wrong.
This one guy on Cardomain has 20's on, but the pics aren't that great- don't know if he did any modifications to it.
93 Saturn? While you're correcting other people's spelling mistakes it could be a good idea to use words that actually exist in the English language. 'Spelt' ???
Kenny - Tire Rack dot Com probably has the same type of affair but I do know that www.DiscountTireDirect.com has a wheel fitment guide...just plug in your specific car's info and it will tell you what wheel diameter(s) you can fit on your car, what backspacing and offset measurements you'll need to fit properly, and if you go with a larger-than-stock diameter wheel/tire it'll tell you what the Plus Sizing for the bigger tires is so that your gear ratio and speedometer reading will remain true.
I want to put 20" rims on my car, it's a 1996 Chrysler LHS- has 17" stock I believe. Would I be able to do it without modification, or would I have to lift it (how much?) Thanks!
i know the newer choncords will fit 22's idk what the older ones will fit....
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
718
I think he wants to use the existing enclosure he has, and its cut out for a single Ten inch sub at the moment
19
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
bigbangtheory
