Wall Port
yes but half the width on each back port. also a V in the middle would be good. csn you not put the port on drivers side?
ok i see , so if the port is 4" then the two back folds should be 2" . . i could do driver side i was just thinking that center ported would give them equal run to the port as I can not stack the 18's vertical evenly (heigth issue) due you think if i positioned them diagonal from each other and did driver side it would be ok ? (have seen that design a few times)
Savag3
sav'd out
Savag3
Central KillaCali
RAM_Designs
