Walk-through < 8 15's
Am working on getting the firewall completely bare so I can weld some plates up instead the cheap seam-sealer the factory uses. Got 3 runs of wire almost ran all the way and the dash is almost out. I don't know now if I want to make my own dash or keep the factory one, the wiring harnesses are a b!tch. I'm also debating on instaling a Painless Wiring kit.
Will get a pic tomorrow.
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
Stream? Unlikely https://www.smsl-audio.com/portal/product/detail/id/809.html https://helmaudio.com/products/boltdac You might can stream in...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
TnT_Sounds
profiling gets **** done!
TnT_Sounds
Colorado
AcidikBass20
    May 16, 2024
    May 16, 2024
