Walk-through < 8 15's
TnT_Sounds
profiling gets **** done!
3,791
Colorado
Finaly got the urge to wall so here's some sort of progress on it. Got laid off from a previous job so I was at a stand still for a while, but am now back on track.
Equipment includes;
8 AA Havoc 15's
4 Sundown 4500s
4 SAX 100.4's
12 AA Carbon fiber mids (6 in each door)
3 DC Power 16v alternators
10-12 Kinetik 16v batteries
200ft of Kicker Hyperflex
So far have mainly the rear suspension done and the frame was powder-coated thanks to Tiny at Tasrop PC.
Also will be repainting the truck and new topper myself when I get it.
Box will look like this
One of the dual alt brackets
some new rims (only 17's)
some woofas
From recooperating from the layoff I am just now getting around to making some more progress. More updates should come to fallow by this weekend. Weather is supposed to be nice //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
duuuude... thats gonna be rediculous
And you had to grace me with the first post!//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
J/K.. It should get down quite well I hope:laugh:
pm me on how you plan on running that 16 volt charging system...im very curious. If you have the time to that is...thanks man.
What would you like to know? My time is expandable and I'm bored out of my fucking mind
i allways have propps for people that build a do things, and your cutting and diceing, i fukn love it thats a bigazz hole in the back...
i heard of a picture of the subs, where is it??????
Awh thanks man:p:
Dont have pics of all the bracing yet either. Those pics are about 1 month old now:crap:
Thanks for reminding me, I need to upload them.
everything...lol. Im thinking about running a 16 volt system for next summer. Your charging system is going to be charging at 17ish or so, right? So this will charge every cell in the battery, and then for your lights, cd player and all that, youll just hook it up to the 12 volt post?
How can you run a 16 volt system when that batts just have two terminals btw, if you dont mind explaining it to me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks
16v alts for the system or just the sub amps..
16v batts for them..
12v alt for the car and mids/highs amps
12v batt
That is about all there is to it.
My stock electrical will be completely away from the 16v setup.
Will have 1 16v batt under the hood and 2 12v batts for the mids and high stuff.
12v batt
so, you couldnt do a 16 volt system with just one alt. charging at 16 volts (i know it will be technically charging at more then this)?
thanks
I will pm you. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
986
Stream? Unlikely https://www.smsl-audio.com/portal/product/detail/id/809.html https://helmaudio.com/products/boltdac You might can stream in...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
TnT_Sounds
TnT_Sounds
Colorado
AcidikBass20
slater
    May 2, 2024
slater
    May 2, 2024
