60_cent
Since I've owned the set up I find myself changing setting all the type. Recently I discovered a setting called rear fill. When using this setting I find that the front channel gets alot louder and sounds more clean at a lower volume however lacks a little low end which is fixed by just turning up the subs. I really like the way it sounds on this setting.
Anyone else used and experienced the same while using this setting?
