voltage
  • 4
youdoofus
Skibidi
its that time of year again where the temp starts to drop and the voltage at my distro block does the opposite. anyone else up in the northland and notice that their voltage has been better at higher amperage draws? I know that there is a science to this phenomenon, but it just got me curious who else has has this same thing happen
From what I can gather, a battery performs best at room temperature. When you deviate from that, performance is affected. Different battery chemistries react differently but generally speaking cold temperatures increase internal resistance which lowers capacity (struggling sound the car makes when you start it mid January in 0 deg temps. Hot temperatures lower resistance but lead to a shorter battery life. Basically batteries perform best at temps that are comfortable to humans. (60-80 deg F)
Hell yeah, y'all scienced the **** outta that.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
422
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
youdoofus
Skibidi
youdoofus
planet earth
youdoofus
    May 16, 2024
    May 16, 2024
