Voltage of Amps...
chibahawk
oe squeezer
MTX Thunder 2150X
Rockford Fosgate 801S Punch
Okay I'm going to be running these two amps in my car. Now I read the specs for the MTX and it says that it operates 75x2 @ 4 ohms at 12.5Volts. Does this mean that some amps run at 12.5V and some amps don't? Can't seem to find what the RF runs at and what kind of difference does it make?
I thought all there was to know about amps was Ohms and Watts //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
oh so basically my MTX amp is gonna pump more juice? I knew 14.4 was the norm which is why I thought when the amp said 12.7 it meant something weird..
Your car at idle = your engine is running. Idle or high rpm - voltage should stay close (this is the job of the Regulator in the ALT) with zero load. At low RPM you may not get as much amperage output
As stated the amps have a some what unregulated power supply, anything above 12.5V will possibly get you more power. They rate the amp at a lower input voltage so you know that is the minimu you should expect from that amp.
chibahawk
oe squeezer
chibahawk
NYC
knukonceptz
