voltage drops.. when does it get dangerous? (perminently)
While we are on the subject...
Could a stock alt handle 2.2krms?
Also could 1 battery handle that? Along with just 5 gauge power wire.
word yeah it definitely didn't drop that low, im guess no less than 13 or mid 12's. yeah i have a 1 farad cap but im not pushing 1k watts. if anything just .5- .65k watts. (with mids and highs added.
i thought caps were do do lol and ppl hated them
yeah i plan on gettin a powermaster d3400 (fits my truck) in the front, and probably another in the back. (if i need it)
and big 3 is already done
Dash volt meters are very slow to respond and not accurate when talking 1-2 volt increments.
I'd put a dmm on it and see what is really going on instead of just guessing.
Different brands will react differently to voltage drops.
Caps are good for smoothing out a good voltage they will not give you what you dont have.
k i see, so its not a terrible idea (won't hurt or hinder) to put that cap back in?
yeah i really just want to replace the batt under the hood, and put something in the back next to my amps. and if i still need to, get a new alt, so there will be absolutely no worries.
no. A stock alt can handle around 1,000 rms and that's about it. Anything more than that you will see voltage drops below 12 easily. Even with caps most likely.
lol agreed
i still have no idea if im ok for now?
i mean my saz 2000d... @ 4 ohms, pushin less that 500watts and a 60x4 channel is makin my volt drop and lights dim pretty significantly.
but then i read ppl saying they push 1k.
so batteries.
how about the powermasters?
could i throw a d3100 in the back and b ok? or do i have to match the batts exactly?
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
636
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
reclessantics
reclessantics
SC
reclessantics
