voltage drops.. when does it get dangerous? (perminently)
yeah i looked into mechman alts.
what would make the bigger difference? batt or alt?
but i was trying to avoid a new alt, 4 batts ect lol
thats why i wanted to keep it around 1k ish watts. new batt up front, was a definite, second big batt in the back, i would probably do to be safe, but much more than that, and i would have goine with a 3k watt amp and done some big **** lol
then just one new batt should be good, if you have the big three you should get a 200 amp alt. if you already dont seeing you got a truck
Dont listen to whatever this guy says...He suggested a cap, need I say more?
It all depends on the amp.
zenon board amps can run down to pretty low voltage.
When GalacticMonkey had his 6 3000d's in his van he would drop down into the 10's the amps would hit thermal protect for a second but after they cooled off they would be 100% good.
I run my D9 at 1ohm and drop down to around 11.6 at full tilt.
I can beat on it all day long it will get warm and thats about it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Once you get below 10V with the sundown amps you'll run into protection issues. I've accidentally ran mine down to 9.7V before going into protect...disconnected power cable.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
499
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
reclessantics
reclessantics
SC
reclessantics
    May 24, 2024
    May 23, 2024
