voltage drop without dimming?
i'm not having voltage drop. I was just asking for the sake of obtaining knowledge.
so if the wiring is good and you are getting serious dimming, then there is voltage drop. The dimming lights is the indication you get.
but if there is no dimming, yet voltage drop is occuring on the amp, would you be able to tell by sound? Would it get softer? Start clipping? What would tell you that someting is wrong?
so if the wiring is good and you are getting serious dimming' date=' then there is voltage drop. The dimming lights is the indication you get.[/quote']
Yes. Lights are actually pretty sensitive indicators.
Hard to say. If there's no light flicker and the amp's input is low, that can only be due to poor wiring or ground to the amp. Different amps behave differently under those conditions. Some will go into protect mode, some will get hot, etc. Whether you'll hear it or not is not certain.
Upgrade just arrived...SHCA Black friday sale for the win. Even more voltage drop, here I come.
18
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
I was thinking 2 aught wire an do you think it would help if i took the secondary battery ground ran it through the ground sensor an tied the...
Beatin'
Beatin'
MI
maylar
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
