voice coil diameter/power handling relation
  • 4
I don't understand the question. Are you wondering how the 15 with a 3" coil is rated at twice the power of a 10 with a 2.5" coil?
Cheap chinese 2.5" coil? Also, it might have a very short wind height. Another possibility is the other mechanical parts on the 10's are weaker and/or lower quality
Pretty much. A half inch difference is not significant, all else being equal. I'd imagine putting in 1,000wrms in a 3" coil is pushing it compared to two 2.5" coils taking 500wrms each.
Pretty much. A half inch difference is not significant' date=' all else being equal. I'd imagine putting in 1,000wrms in a 3" coil is pushing it compared to two 2.5" coils taking 500wrms each.[/quote']
Lol, I had a 7k amp on one 3" coil sub and it was fine
1,000 RMS clean is nothing for a good quality 3" coil
The overall voice coil diameter is not the only deciding factor that determines power handling. You have soft parts, motor cooling, number of layers, how the voice coil is wound (ie flat, edge, round etc), former material, former dimensions, voice coil material, voice coil dimensions, adhesives, and other details I may be missing.
1/2" is actually pretty significant when it comes to thermal handling. That's a whole lot more copper when you think about it.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
497
I looked at Crutchfield. Sure enough, dudes right up does say it. I even looked on YouTube. There's only 1 review on the m7 subs, but it's...
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
884
Beatin'
Beatin'
MI
fatboytyler
    May 18, 2024
    May 18, 2024
