Viper 5706v won't start my 2010 Chevy Malibu
  • 2
Lopezjorge123
I just finished installing the viper 5706v with the directed DBALL2. I have it hooked up W2W not D2D. I followed wiring diagrams to the T and I'm having a problem with the remote start function. The alarm seems to be working fine. Lock,unlock,trunk, work just fine. Yet doest star the car. After about an hour of troubleshooting I notice that it does work if the key is inserted in the off position and it will shut off after the preset time too. Normally A sign that a bypass is needed, but I do have one, I programmed the key over and over but it was the same. I also reflashed the DBALL2 but still the same problem. Any ideas on what I may be doing wrong? thanks in advance
Did you connect the remote start to the correct ignition wire?
The year comes default with remote start so it may still have the old one active
Sent from my draconis using Tapatalk
Yes this car only has 1 ignition wire. I double and triple checked my wiring. I'm really starting to think its a faulty dball2 I can't think of what may be keeping it from starting the car. BTW, it didn't have remote start from factory. It's the LS version.
피크를 사용하지 않을 계획입니다.
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
172
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
Lopezjorge123
Lopezjorge123
Chicago, il
Lopezjorge123
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
