Well, let me put it this way. I couldnt see anything blatantly wrong that I could point out, also no noises were obvious. Mainly because the sound pressure was bottoming out the cameras mic (like most any vid does) so if there was any other noise there I couldnt pick it up.
Any bottoming out might just be from either too much power, or it was just being played below the tuning freq. Even with the 20.1 @ its lowest gaings setting, its still putting out quite a bit of power at 0.5ohms.
Im not sure what the xmax is on those subs, but they were stretching quite a bit. Might just be at its mechanical limits. When you pull the sub just look around for anything obvious. If the cone was hitting something other then the tinsels, some markings should be visable.
Do what you gotta do, worst comes to worst...time for an upgrade.
Good luck.
