- Thread Starter
- #31
Ok, you likely don't have issues except for levels then, is what it sounds like. Are you running passive or active? Basically, do you have one channel for each tweeter and midbass, or are you running rears? You may have a switch on your crossover if you are running passive, or you can turn that channel down if you are running active. And when you say "super high volume", what number is that on the deck?
60 degrees, top of faceplate angled up.
I seriously cant get the faceplate back on unless I seat the left side, then press hard on the right, when I try angled with the top out it just binds and gets stuck in the gear on the left.. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I must be retarded. I looked at the mid/high amp, and the crossover frequency looks to be ~80-100hz... ill post a pic of it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif As for active or passive its passive, only front stage, just left and right channel split to tweet/mid in the door with a crossover. When I say high volume i just mean the vocals are to **** loud.. But the deck volume is ~40.. Perfect example, I was just driving home form work, playing some Kaliko, one song, okay highs, good mid bass and sub. even got steering wheel flex listening at 45 volume. Next song, I know has bass (Listening to it on my headphones right now :\ ) but the vocals were screaming, so I turned it down to ~32, but no bass what so ever, even fiddled the gain knob all the way home //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Sorry for the horrible picture quality
