very confused
I HAVE DECIDED TO GO WITH FI Car audio.
how can i get help on which ones to get cuz ppl are sayin 1 18 and some are saying 2 12s
my main concern is how big approx is the 18 inch box gonna be? i like the sound of 1 18
ALSO THE Q THE BL OR THE BLT?
Bacon and tomato are alright, but I wouldn't get lettuce on it.
my bad lol i meant the btl
;)If you're going with one of the subs you listed you only have enough power for one sub. The Q would be the best with the power you have available. As was already said, find out how much room you have to work with and get the biggest one you can fit a proper enclosure for.
Q18
DUAL 1 | DUAL 2
Fs: 24.5 Hz | 23.8 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Cms: 0.13mm/N | 0.13mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 268 l | 268 l
Spl: 89.7dB 1W/1m | 89.4dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
Product code: 01718
Price: $ 294.00
i have no idea how to figure that out.. i have a 2004 nissan xterra. i think im going to go with the 15 cuz some one just quoted me 350 just for a box for the 18inch....
is it hard to make ur own?
Just measure all the space you're willing to give up (length x width x height) and from there we can figure how many square feet you have. If you have basic woodworking skills making a box isn't too hard. If you decide to go ported I'd have someone design it for you so you can get the port right though.
Q18
DUAL 1 | DUAL 2
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Vas: 268 l | 268 l
Xmax: 27mm
Rms: 1000W
Sub OD: 18.500”
Cut ID: 16.750”
Product code: 01718
if i can ddo the lowest cubic feet that would work? and how do u tune a box lol?
The size of the port in relation to the size of the box is what determines the tuning. To tune low like you need to do with the Q on a box that big requires a big port which you have to subtract from your 9 cubic feet.
farmerehsan
144.6 db
farmerehsan
Tampa
BobbyDD
