Vented box question... HELP?!?!
fochops
So I have the specs for my particular sub. It is a 12 that will require 2.0 cubic ft, it has a design for a square box with dimensions and a slot vent tuned to the correct FQ. My question is that a square/rectangle box will not work for my situation. So if I keep the same amount of airspace with a different shaped box can I still use their vent specs?
The runner has great acoustics. Not looking for crazy SPL as I know it is unattainable with my setup but I do want the low tones apparent and clean. I'm building a box that will be in the passenger side that will go from the floor up over the wheelwell kinda shaped like an "L". The sub is a SVC 4ohm sub.
Cool, thanks a lot! I've also heard of aero ports, is it worth my time and money? Or should i just make the slot vent since I'll be building the box anyway and will have the material (wood) on hand? thx again...
Kinda wanted to have a clean unassuming box that was more or less out of the way. I do a lot of camping/offroading so I need to retain "some" space back there... Idk what I'm going to end up with but it will be built Sunday. Rest assured that I will post pics and dimensions when done. I heard from one person that factory port specs can be used if the overall airspace is the same. I guess that's all I needed to hear to tackle this project! Haha
Definitely 2 12's then.
311
644
492
I have been attempting to study the true nature of why we tend to tune transmission lines and enclosures in general like we do, the nature of...
Go get some shitty wood or cardboard or something and figure out what the max is, play around with different dimensions to see what the max cubic...
23
fochops
fochops
Poeria, AZ
gckless
DEW123
    May 7, 2024
DEW123
    May 7, 2024
