Sold Various audio items, amps, subs, etc.....
BamBamVan
Mwspl Promoter
Hello I currently am doing some cleaning and looking to sell some items i have accumilated over the years
Ruff idea on Pricing will consider Offers
All items are used and in Great working condition. Have receipts and boxes for allmost everything.
1 D2400.1 Directed amps $215
1 D1500.1 Directed amp $175
1 D1200.1 Viper amp $175
1 50.2 Directed amp $59
1 4.600 Orion amp $160
1 30.2? Alpine amp $60
1 4.800 PPi amp $225
5 12" Kicker L7 subwoofers with grills $475 ( two are silver 05's & other three are black 06's)
3 12" Alumapro Alchamy SQ subwoofers in sealed box $350
1 10"Alpine xr in bandbass box $67
The four 18" RD heavy weights with 4 recones $1,600 pluss shipping.Woofers are dual 2ohm, recones are dual 1 ohm
Also have two Cactus sounds 5kw amp's
Two cactus sounds cs9000 batteries
Undecided on selling amps n batts. But if good offer may sell *
PowerMaster 12/16 volt agm/leadacid Battery charger $300
Clarion indash 6.5" monitor fm/am tuner(older monitor non cd or dvd aux video input) $275
Link of specs and pics of 4600 orion amp
http://www.orioncaraudio.com/Products/Products.aspx?ProductID=504
1500 D specs
Product Features:
*High speed MOSFET switching power supply
*High current, high efficiency MOSFET outputs
*Switchable 8 dB bass EQ
*180° phase invert switch
*Remote subwoofer level control function
*Thermal, DC offset, reverse polarity and short circuit protection
Product Specifications:
Dynamic Power Rating: 1500 watts >80 dB
Freq. Range: 20-250Hz
Damping Factor: > 50
Input Sensitivity: 150mV to 8V
Rated Power @ 4 ohm: 425 x 1
Rated Power @ 2 ohm: 800 x 1
Rated Power @ 1 ohm: 1200 x 1
Crossover Variance: 18dB low-pass
Bass EQ: Yes 8 dB
RCA Output: Yes, mono
Protection: T,S,D,R,O,L
2400 D specs
Features:
Model D2400
Digial Class "D" Power Supply
Max Power Rating 2400 watts
Mono amp
CEA Rated and tested RMS Power: 800W x 1 RMS @ 2 ohm
CEA Rated and tested RMS Power: 1200 x 1 RMS @ 1 ohm
Freq. Range 20-250Hz
Damping Factor >50
Input Sens. 150mV to 7.5V
Low pass Crossover Adjustable @ 12dB
Built in Bass EQ
RCA Output
Thermal, Short, Overload, DC Offset, Revers Polarity, Overvoltage, and Under voltage protection
Dimensions - inches W:14-1/4 x H:2-1/2 x L:12-5/8
bass knob included
PWM design runs much cooler than other amps
High-speed MOSFET switching power supply
High-current makes this a true 1 ohm stable amp
Adjustable 24dB/Octave subsonic filter
Adjustable 180° phase inversion
Master/Slave Function
Adjustable input sensitivity: 150mV - 7.5V
Chrome-plated terminals
Rugged 2-piece heat sink and cover
Fuse Rating: 120A (3 x 40A)
50.2 directed
Model A502
Max Power Rating 500 watts
CEA Primary Power (power into 4 ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 90W x 2
CEA S/N Ratio (referenced at 1 watt/4 ohm) 70dB
CEA Additional Power (power into X ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 125W x 2
@ 2 ohm
Freq. Range 20-20K Hz
Damping Factor >200
Crossover var. 12dB
2-way
Bass EQ Yes 8db
RCA Output Yes, stereo
Protection T,S,D,R
Dimensions - inches W:10-3/4
H:2-1/2
L:11-3/8
Metric - mm W:273
H:63.5
L:290
T = Thermal, S = Short Circuit, D = DC offset, R = Reverse polarity, O = Over voltage, L = Under voltage
link to more specs
http://www.drdetailshop.com/da502.htm
The 18" Rd heavys are DUAL 2 ohms currently and recones are set up as DUAL 1 ohm.
BamBamVan
Mwspl Promoter
BamBamVan
Southern Minnesota
BamBamVan
