Hi everyone,
Hopefully someone can point me in the right direction,
Had speakers installed, sub, amp and headunit however finding I need more bass and clarity out off the speakers so they are not distorting as much..
Currently when I have it turned up quite loud for 20-30mins with bass booster on the amp cuts out and is super hot?
Current setup hyandia iload work van -
*JVC - KW-V220BT double din
*Alpine type S speakers each door with tweeters
*DB Drive - A6 1200w:4 channel amp
*Soundstream STEALTH-13 / slim sub
Ok so my project is to increase the bass and also have increased volume with clarity.
My options are due to space I can only put a sub In between cage barrier and the seats, fits perfectly and also have 2 x 6x9's on the rear door panel. Possibly using the current amp I have to run the speakers and buying another amp to run both subs.
What are your thoughts ?? Budget is I would like to spend roughly less than $1000 excluding the sub - however I don't mind spending more if it is going to make a huge difference.
What amp would I need for both subs?
What speakers would you recommend?
Is my current speakers and amp good enough?
Thanks heaps look forward to your response guys!!
