using LPF on HU or amp
pentavolvo
I have a Pioneer DEH-P6500 which has a low pass filter built into the HU's sub controls, and my Profile California CA400 had a varaible LPF/HPF. Do I want to use the LPF in the HU and turn the filter off on the amp, or turn it off on my HU and control and use the LPF on the amp.
Thanks
i use my HU LPF at 78hz but you amp will override anything less than that depending if you have it set to or not. the HPF in my case was very helpful b/c i dotn have an amp pushing my components or my tweets and its set to 125hz and up ..... atleast its better than hearing below 125hz notes thru tweets //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
using btoh wont hurt. it might be better to, in case one of them fail (doubt it) or u set the lpf in amp at a higher freq dat u would want by accident.
The amplifier typically has a higher quality crossover than the head unit, so I tend to use only the amplifier's crossover ...
My experience as well. More specifically: 1st order -6dB/octave, 2nd order -12dB/octave, 3rd order -18dB/octave. The lower order the more frequencies above cut-off pass through.
The HU x-over is likely a lower-order than the amp. Nice thing about using the HU x-over is you have sub bass-boost control right at the deck. If you dont have a control from your amp up front, I would recommend using your HU x-over (so you can have sub bass-boost control) and using your amp x-over, as well, at a slightly higher point than the HU setting.
Also, when you put the Pioneer decks in subout mode, the rear speaker outputs are also affected. If you're running rear fill off the deck speaker outputs, that sucks.
It's that way with my 6400, dunno about the 6500.
Well, you'd have sub level control at the head unit anyways, so there's no real point in using the HU's crossover since you can always turn the crossover off and leave the sub pre-out on ...QUOTE]
This wasn't the case while I temporarily used a Pioneer DEH-3500. You had to choose a crossver point if the sub pre-out was on. Consequently, you could only control sub bass-level at the crossover point you chose. Granted the 3500 was an entry-level deck - if the Poster's 6500 can control sub bass-level at the pre-out without using the HU x-over, then of course go with the higher order.
why would the sub preout effect the rear speakers. the head unit(i have the same one) has three outputs sub, front, and rear. i dont think you can control the sub output without having the filter on. but i cant remember. i use the lowpass filter on both amp and headunit.
pentavolvo
pentavolvo
Chicago
99concorde
vegang
vegang
