Using DMM question
bjfish11
FisherCustoms.com
Before i get hounded, i did a lot of searching already. Now to set my gains....600w RMS x 2 (sqrt)=34.6 volts.Now how exactly do i do this using my DMM. Bought a red and black iEquus Innova from Wally world ($25). I think i turn it to the first setting to the right (DCV) is this correct? Next, set my volume to max i listen to and then thats where im lost. Do i just plug my DMM things into the speaker outs on the amp? Well when i do this, by volts start jumping all around and i cant get a steady reading. Can someone please help me out here. Thanks.
also, do is it a MUST to use a test tone when setting them. Where can i get them if so? i tried the link in the gain setting tutorial and it was unavailable. Box is tuned to 36 hz if that is necessary info. Thanks again.
question.. dont mean to steal thread at all but it might be helpful to the thread started as well..
when i try it i keep getting a really low voltage.. like .20 or.25.. whats goin on?
and hifonics has 2 terminals that internally bridge.. so how would i measure for 1 ohm application? would i use it as if i were running a single speaker at one ohm?
the easy way to set your gain
turn your sub off
turn your deck up the most you ever listen to it
adjust your bass, treble etc, how you like it
turn your sub on
play a 50hz or so test tone
turn the amp gain up until the sub no longer gets louder
then back it off a hair
your done
just went out and tried this.... 50 hz. test tone, turned DMM to ACV and plugged into speaker outs on the amp. started to adjust gain higher and higher, got up to 15.09 and my gain was all the way up. I need to get up to 34.6. Whats the deal.
do you have a sub-out level on your HU? If yes, then it needs to be all the way up.
bjfish11
FisherCustoms.com
bjfish11
Garden Plain, KS
bjfish11
