Using both RCA inputs.
  • 2
Mamemba
Was wondering if it's necessary to use both RCA inpits on my amp? I have the JBL 600.1 Does anybody know anything about this? I currently have one set of RCA's running to the amp and it seems to sound great. Could the extra low level input affect the performance of my amp? Would it sound any better?
Thanks for the previous help too all.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the second set of rca inputs is to eliminate the loss of bass which may be caused by the use of the fader control on your HU. if you have the fader set to about midpoint and are using the rear rca output to your amp then you won't need a second set of rca's.
Thanks for the advice imral3 appreciate it!!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
919
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
754
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
Mamemba
Mamemba
B.C. Canada
Mamemba
