using a maxxlink ... wtf?
It says that using the maxxsonics Maxx-link mlx-100 that you can link up to 5 amps max.... So say for instance I got 3 cheap amps that state that they are 4000 watt amps.... and linked 3 of these amps together (say realistically they only get at best about 1000 rms for each) how would I wire 3 of these amps to 1 sub? its basically a module that allows you to strap up to 5 amps together right? or would I be strapping 2 amps together for one coil and then using another say 2 amps for a total of 4 amps to the neg? I'm just really confused as to how you would wire more than 2 amps to a single sub. The sub i have is a D2 sub setup as well. any and all help is very much welcomed!
I think you are reading it wrong. Its link up to FIVE AMP PAIRS. Thats pairs of two amps. So saying that. You can hook up four amps to one sub.
- Allows interconnectivity / linking mobile amplifiers into a "master and slave" configuration
- Link up to five (5) amplifier pairs- Remote level control with LED clipping indicator
- Master / Slave control switch
- 24dB adjustable low-pass (35Hz to 250Hz)
- Built-in 6.5Hz set-up test tone
- 24dB adjustable subsonic filter (15Hz to 35 Hz)
- 10dB adjustable parametric bass EQ
- Variable wide / narrow bandwidth control
- Built-in line driver variable from 1-9 volts
- 0 to 180¡ adjustable phase control
- 2-channel RCA audio pass-thru
now say i use the maxxlink and use amps that are not designed to be a master/ slave setup. and are stable down to one ohm each. if i use something like this what kind of ohm load does each amp see? like for instance if i wire the terminal at the box at 1 ohm does each amp see a 1 ohm load or does it see a .5 ohm load?
Depends on how many amps you run. If you run 2 each amp would see .5 3 amps would be .33 4 would be .25. you would need a 3ohm nominal load so each amps load is as close to 1ohm if your running 3 amps.
Just asking do you own one?? I say this because you say three amps. That is not how its made. Its made to run pairs of amps. Not a pair then a single amp. It can run up to 5 PAIRS of amps.
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif :crap: //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
total fialure
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif :fyi: //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
total fialure
i lol'd fur real
lovindabass
Banned
lovindabass
brooks,Ga
audioatg
